- Select IS-IS.
- Select the Protocol Summary tab.
Protocol Summary Field Descriptions
Use the data in the following table to use the Protocol Summary tab.
| Name | Description |
| Globals ISIS | |
| AdminState | Indicates the global status of IS-IS on the switch. |
| SystemId | Indicates the IS-IS system ID for the switch. Valid value is a 6–byte value in the format <xxxx.xxxx.xxxx> |
| HostName | Indicates IS-IS system name. This may be used as the host name for dynamic host name exchange in accordance with RFC 2763. By default, IS-IS system name uses global system name as it is synchronized with the IS-IS system name until the IS-IS sytem name is manually configured. |
| Globals SPBM | |
| GlobalEnable | Indicates whether SPBM is enabled or disabled at the global level. |
| NodeNickName | Indicates the nickname for the SPBM instance globally. Valid value is 2.5 bytes in the format <x.xx.xx>. |
| PrimaryVlan | Indicates the primary VLAN ID for this SPBM instance. |
| SmltSplitBEB | Indicates whether the switch is the primary or secondary IST peer. |
| ISIS Interfaces | |
| Circuit Index | Displays the identifier of this IS-IS circuit, unique within the Intermediate System. This is for SNMP Indexing purposes only and need not have any relation to any protocol value. |
| IfIndex | Indicates the interface to which this circuit corresponds. |
| AdminState | Indicates the administrative state of the circuit: on or off. |
| OperState | Indicates the operational state of the circuit: up or down. |
| ISIS Adjacency View | |
| Circuit Index | Displays the identifier of this IS-IS circuit, unique within the Intermediate System. This value is for SNMP Indexing purposes only and need not have any relation to any protocol value. |
| AdjIndex | Displays a unique value identifying the IS adjacency from all other such adjacencies on this circuit. This value is automatically assigned by the system when the adjacency is created |
| AdjIfIndex | Indicates the interface to which this circuit corresponds. |
| AdjState | Indicates the state of the adjacency:
| AdjNeighSysID | Indicates the system ID of the neighboring Intermediate System. |
| AdjHostName | Indicates the host name listed in the LSP, or the IS-IS system name. The IS-IS system name uses global system name, if the host name is not configured. |
